my second 81 srx almost finished
Re: my second 81 srx almost finished
Post by chrisrider63 »
Just trying to help keith and as you can see speed agrees with me. I know you put a lot of money into the project but if you sold the bottom end for $2000 it would finance half of your project.
Speednutt
Post by Speednutt »
Is it possible that someone just stamped the serial number on a updated 81 case? The 81 cases that had the crank update came with no serial number. As you can see the R and the T are not perfectly aligned and that may be what makes it a correct 500 case, i dont know. I just know that with just a plain surface and a set of punches, it wouldnt take much to make that happen. Hope it is a real one.
(2) - 87 Vmax 540
(2) - 93 Exciter SX 570
Snowmobile Toolbar
www.excitersx.com
www.racenssr.com
yes very true
chrisrider63 wrote:yes very true
i have a real srx 500 bottom end
i also have a srx 440 motor with no numbers
i just checked the oil pump and the number on it is 8R9 that came with the motor.
Keith3046 wrote:i just checked the oil pump and the number on it is 8R9 that came with the motor.
Neat....! As you can see this engine must have been from Canada. viewtopic.php?f=2&t=585
SRX500F82
Post by SRX500F82 »
Speednutt wrote:Is it possible that someone just stamped the serial number on a updated 81 case? The 81 cases that had the crank update came with no serial number. As you can see the R and the T are not perfectly aligned and that may be what makes it a correct 500 case, i dont know. I just know that with just a plain surface and a set of punches, it wouldnt take much to make that happen. Hope it is a real one.
Here are two SRX 500 Cases from Sleds that are in SWEDEN.
