My 84 VMAX won't start
Posted: Sun Nov 12, 2006 4:29 am
I'm having some trouble getting my VMAX to cooperate. Maybe it likes being in a warm shop? Here's a list of things I've done and what the sled is doing. If anyone has any ideas I'm all ears.
Things I've done
Purged all old gas, drained and cleaned carbs
New, high octane gas with octane booster (should be around 93)
Replaced CDI with used one
Replaced coil with new one
Checked all resistances and ground continuities. (checks out ok)
New spark plugs
Checked timing using dial indicator method. (looks good)
Shot of fuel direct into cylinders (no effect)
Checked compression (125 psi both cylinders)
What's happening
With plugs out, the spark jumps a 1 cm (3/8") gap
The plugs seem to be firing at the same time (I thought they should alternate)
The engine will "pop" every third or fourth pull, but only the left side. It seems like a backfire. The exhuast pipe does get warm.
Tried starting with and without choke, with and without throttle.
Both plugs are getting damp with fuel. (I don't think it's fooding)
My arms are getting longer (and really tired)
Thanks for any and all help,
Stephan
Things I've done
New spark plugs
What's happening
Stephan
