				Secondary Clutch Preload
				Posted: Mon Dec 14, 2009 9:05 pm
				by Fs Motorsports
				Hopefully someone can refresh my tired brain on how to preload and which way to turn the clutch to ge the best results..
Thanks in Advance All,
Steve
				Posted: Tue Dec 15, 2009 1:38 pm
				Primary Spring Color/ Length/ Rate/ Preload Pink/ 75.5mm/ 2.31Kg-mm/ 32.8 Kg
Secondary Spring Preload/ Color/ Length 40degrees (C-2)/ Pink/ NA
I don't have a secondary here at work but, if memory serves me right....... with the clutch face down and the helix up turn the sheve clock wise which pre loads the spring, until the helix slides down into the opening.
				Posted: Tue Dec 15, 2009 6:12 pm
				by Fs Motorsports
				Thanks for the info, Will it only turn so far or these a degree I should be going for ?
Steve
				Posted: Wed Dec 16, 2009 8:33 am
				40degrees Holes(C-20)
Just turn until the clogs of the helix fit into the sheeve.
