Headlight wattage
Headlight wattage
I read Tylers report on LED tail lights and plan to order one, I also would like to order the higher wattage head lites at the same time. I did have a problem with the handwarmers dimming my lite. So the question is, has any one run the 100 w or 130 w headlight bulbs? From what I read hand warmers can draw from 20-40 watts, thats enought to dim my 60 w bulb so are the higher wattage bulbs just going to be dimmer anyhow? Anyone tried one?
						I would start with a red LED tail light and then see if you are happy with the head light.  All hallogen bulbs degrade over time, maybe just replace it with new ?  130 watt bulb would probably pull the voltage down and dim the light or fry the L. coil.  Wonder if they make a H.P. brighter white bulb of the same or slightly higher wattage ?
Who wants to be the ginny p...... ?
http://www.bluhmenterprises.com/product ... gory_id=15
or
http://cgi.ebay.com/ebaymotors/Xenon-co ... 518615f8ee
http://motors.desc.shop.ebay.com/i.html ... 448&_rdc=1
or
