81 SRX flywheel and lighting coil.
Posted: Mon Feb 01, 2010 11:46 pm
				Hey guys,
I recently obtained an SRX 440 that runs great. It just has had no lights since I got it. I narrowed it down to the lighting coil. It ohmed out correctly, but the lights barely lit up. Its not the light bulbs as when I pulled the coil wires off, and clipped on a battery, all the lights work perfectly.
Turns out, when I pulled the flywheel off, there was a lot of surface rust on the inside of the flywheel. I'm surprised the engine had spark. I've cleaned that up with some 400 grit sandpaper. This sled sat for many years in somebodys garage.
Anyway, I'm picking up a lighting coil tomorrow, but I have a few questions.
Should I try to snake the new yellow wire through the grommet, or just crimp it to the existing yellow wire inside? Seems impossible to put the wire through the grommet, and I don't want to pull the other two coils out in fear of messing something up.
Also, what torque should the flywheel nut be? I don't have a manual.
How much oil should be in that white inspection plug?
Ryan.
Ryan.
