I am rbuilding a 83 Vmax and I would to check the lighting and charging coil specs before I put the motor back in the sled does anyone have the the numbers on the omh's.
Thanks Ken
1983 Vmax Coil Specs
Re: 1983 Vmax Coil Specs
Ken
Also, see below link...
Chuck
Chuck
Ok so the 83 is the same as the 86.
The coil show the ohm's to be 245 plus or minus 10% my is at 188 would you say that I would have to replace it??
I would replace if nothing else it is a pain to get to and looking at being stranded is no fun.1977srx wrote:The coil show the ohm's to be 245 plus or minus 10% my is at 188 would you say that I would have to replace it??
