				Yamaha secondary clutch on a 540 v-max?
				Posted: Fri Dec 12, 2008 9:17 pm
				by chrisrider63
				I wanna put a secondary clutch from a 81 srx 440 onto a 540 v-max would it work right??
				Posted: Wed Dec 17, 2008 1:01 am
				yeah it should work alright.... set your spring to c2 i believe (too many numbers in the last couple days i cant be certian)
				Posted: Sun Jan 04, 2009 8:24 pm
				by Marc Machine
				Tyler440 is right.  Standard spring position "C" in the number 2 hole.
				Preload
				Posted: Sat Jan 24, 2009 4:49 pm
				by Fs Motorsports
				Marc Machine wrote:Tyler440 is right.  Standard spring position "C" in the number 2 hole.
Do you need to preload these when putting them back together ?
Thanks Guys,
Steve
				Posted: Sat Jan 24, 2009 8:24 pm
				by vmax-540
				You should also change the spring, the SRX had a yellow spring and the Vmax had a pink spring the pink one has a lot more tention. The yellow is just to lite for the Vmax.
