Hey guys, I'm having trouble figuring out the correct fuel line and oil line routing on this engine. Someone had a fuel filter on the impulse line on one of the fuel pumps. It has 3 different types of line on it and the oil pump is not hooked up at all.
The fuel pump for one carb was connected to the impulse nipple under the opposite carburetor. Is that the correct way of doing it? Do the oil feed T's go before the pump? I saw a picture of one setup like that. The manual is no help at all and I have to be sure to clear the airbox.
Thanks guys.
James
85 Vmax fuel and oil line routing
Keith.Dumoulin
mustanglx_1989
Re: 85 Vmax fuel and oil line routing
I ran across that before. Unfortunately it doesn't show the fuel lines and where they go.
I could email these in a PDF ?
mustanglx_1989
That is exactly what I am looking for! I don't know how you find this stuff, but its great. I would love a copy to print out. Thank you for all of your help so far.
James
mustanglx_1989@yahoo.com
James
AdrenalineJunky
None of those actually show oil tank lines to oil pump, and oil pump to fuel lines. Looks like maybe part of the diagram is cut off in the picture?
