A revalation
Vmosheen
A revalation
Post by Vmosheen »
Thats what is wrong with my 83... I'm getting coolant in my gear case. It spews out the breather. What can I do to fix this? The thing runs sweet until the stator gets wet and shorts out the spark.. Any help on this would be huge. This problem has been going on for two seasons now.
Post by opsled »
Water pump seals. It needs to be fixed and soon before the entire gearcase gets wrecked from the antifreeze if it's not allready.
Vmosheen
Post by Vmosheen »
Thanks for the tip. Can I get to the seals without pulling the motor?. Are the still available through Yamaha?
See the top Sticky post in this Forum........ http://www.vintagevmax.com/vvforum/view ... highlight=
B.T.W. I'm presently working with a guy from Erie Bearing on a solution and will keep everyone informed !
