need help new vmax owner
vmax540liq
- Contact:
no i put that in my chain case i didnt put anything in my crankcase deal with the dip stick i put the dextron automatic tranny fluid in my chain casing, i just took it out back and ran out of gas but damn was it running good on the bottomend pullin the skis everytime i gave her some throttle but now with the snow melting its all rock hard and i have a stock track on mine which sucks for getting thru powder really bad but with the great studs i have it picksup and goes now.
"The only way to drain the oil is to remove the plug in the bottom of the case which requires unbolting and lifting the engine."
Actually, there is a small hard to notice and if you do you brush it off as nothing plate on the belly pan which is directly below the drain bolt. It's held in place by one rivet and one phillps head screw which you loosen and swivel the plate !
