My bad luck with these sleds continues!
Well, For 3 years now I've had an 83 that Ran ok but I could never seem to get it dialed in in the clutches no matter what I tried. Decided to pass it on and start over.
						Some new sleds have a switch that is used to richen when using Ethanol, that and if you have ported cylinders/gutted airbox/air leak or even bad gas could easliy cause a melt down. If only the PTO cylinder is affected, I would look closely at that carb to airbox boot or the carb to cylinder rubber mount. The PTO which is the most likely seal to leak can be checked with a running engine and while spraying starting fluid on the seal if the engine revs on its own you have found a leaking seal. A seal kit is cheap insurance much less exspensive than cylinders and pistons.zachalyse wrote:Is a #310 main jet safe for this sled running in Maine at 25 F along with the new ethanol gas? Could this be my problem?
When you see grey (or silver) on the plugs that is usually the melted aluminum from the piston.zachalyse wrote:After reading some posts in hear I'm beginning to wonder if it was a stuck thermostat. At no point did the guage move up towards the red. After the meltdown, one plug looked perfect and the pto side plug was kind of a dry grey. Does this sound like the problem?
Grey-Silver on the plugs is a tell-tale sign that you burned down.
How long where you running 40 mph (around half throttle I would assume)?
It is also very easy to burn down at partial throttle openings.
Usually a hole in the piston is from detonation, caused by bad gas, ignition timing to far advanced, or octane rating is to low for the compression rating.
I would check your timing and compression.
Always use good high octane fuel.
Good luck...................jipcee
Every time I see the sticker on my filler lid cover that says,
"Use Regular Leaded Fuel of no less than 93 Octane"
I have to chuckle.
When was the last time you saw 93 octane Regular?
It has been quite a while since I saw any 93 octane Premium.
The best I can find at a gas station around here is 92 octane unleaded with 10% ethanol.
I can get race gas in the summer at the race track, but it is harder to find in the winter when the track is closed.
I have to chuckle.
