rear guide wheel
rear guide wheel
Thanks for all of the feedback,  I appreciate it.  I'm bringing the sled to my Yamaha buddy this week.  This guy is good.  He has worked on my other toys.  So I had a chance to go through the sled with a fine tooth comb.  Upon inspection of the track and suspension I noticed a circular hairline crack around the bearing of the right rear guide wheel.  Is this a common part? Also the track, which is not cleated or spiked is showing some signs of wear, mostly weather checked, four outside rubber paddles are also broken off.  I think for safety sakes I will replace both.  I don't want to be taken to the bank( knowing OEM tracks are around five bills uninstalled) but I do want a reliable machine.  I have two trips planned this winter, one up to Three Lakes WI, and the other to Jordan Lake outside Portage.  I think this track measures 121"x 15".  Is Camoplast the way to go? Thanks
						Ebay is the place to find new or good used tracks with ~3/4"-1" lugs very reasonable since many have taken them off to upgrade to taller or longer tracks !
