Friends, I have noticed coolant coming from my water pump gear oil breather!  Most likely the seal.  I have the engine out and all bolts removed inside the flywheel housing.  It is off the crankcase by a couple of mms and is sort of loose.  Anyone know the best method for getting off the rest of the way?
STeve
						85 Vmax 540 - Flywheel Housing/Water Pump Housing Removal?
Welcome to V.V. !  Check out the sticky post at the top of this forum ( infamous 1983 water pump seal )
