Hopefully someone can refresh my tired brain on how to preload and which way to turn the clutch to ge the best results..
Thanks in Advance All,
Steve
						Secondary Clutch Preload
				Fs Motorsports
Primary Spring Color/ Length/ Rate/ Preload Pink/ 75.5mm/ 2.31Kg-mm/ 32.8 Kg
Secondary Spring Preload/ Color/ Length 40degrees (C-2)/ Pink/ NA
I don't have a secondary here at work but, if memory serves me right....... with the clutch face down and the helix up turn the sheve clock wise which pre loads the spring, until the helix slides down into the opening.
				Fs Motorsports
40degrees Holes(C-20)
Just turn until the clogs of the helix fit into the sheeve.
