SRX tunning
SRX tunning
I have 38 round slides to put on my 81 SRX  440 but they are not they v-max type and do not have power-jets....Also my friend has a pair of butterfly carbs for the srx should I just buy them??
						your question is... (ive been talking to him via PM)
what would you jet 38mm NON powerjet carbs to to run on a srx440?... or should he just buy the butterflies from his friend
i have always heard the the 38's on a srx get jetter about the same as a vmax... but without powerjets i guess you need to go up on the main jet... maybe ~340 mains?
I had 330's in the PJ carbs was very lean in midrange. Wanted to go to 340, but they seem to all be in the other sleds so Iwent to 350 and dropped the needles. I know theres 340's in the SRV which right now makes a bit more power, those are 39.5 non PJ carbs.
I als went from 40 to 55 on the piolet jets. It was about 700 deg at high idle, now its at 400 and starts much easier. Will let you know more this weekend. Anyone around here going to the races at Plymouth?
yo
Your talking the SRX not the v-max right??
here another thing to consider.... if you run slides you gotta also run the throttle block form the 83+... the thumb throttle on the srx will not pull the slides all the way open... i just remembered that.... also... if you run the 83+ the kill switch will not plug into the 81 harness... i cut and spliced mine it really wasnt hard
