REPAINTING 94 VMAX 600
HEY GUYS..........I THOUGHT IT WAS ON THIS SITE WHERE ONE OF THE FOLKS HAD REPAINTED A 94 OR LATER VMAX. JUST WONDERIN IF I SAW IT HERE OR ON ANOTHER SITE. I KNOW HOW 2 DO THE GLASS WORK BUT AM UNSURE OF WHAT KINDA PAINT 2 USE ON THE SIDE PANELS AS THEY R FLEXIBALE. THANX 4 ANY HELP
Jim, any good automotive paint supply can fix you up with the additive that is used in paint for flexible plastic auto bumpers.
Paint http://www.color-rite.com/
Jim, you can find pix of my sled in this sec. under VooDoo Max I did custom paint for a living. My sled came with 2 sets of panels, I saved the good '83 set if I want to put it back to stock. The Alum side panels I used were very rough and dented, and I had to weld up several cracks, the hood was cracked. I treated it just like anything else. I used bondo then just used air dry primers which really I never used for years on customer stuff. Today's 2 part products are really much better but I just used up what was here. After a season of hard riding, it has held up just fine.
I did used high quality paint for the color coats, this is mostly House of Kolor with a few PPG colors in the art work and HOK urethane clear. I wet sanded the clear down to 2000 grit, then left most of it flat for the flat black look, the only glossy part is where the main lettering is I'm debating right now weather I want to buff it all out , or leave it flat.
The most important step in painting is getting, and keeping it clean between steps, use both a solvent based cleaner and a water based soap.
The flex additive is not a bad idea, I do that on some of our karts because they really take a beating
jim,
your catching it right at the end of season.... and everyone is switching gears again... back in december and jan. this place was hoppin! more so this year than any other year i think... it keeps getting bigger every year which is great
hahahaha that reminds me of on christmas vacation where cousine eddies says
"that there, clark, is an "RV" " hahaha
