(Take it all for $350),,Over $1000 in parts,,Need them gone ASAP
$10.00 Radiator
$10.00 Radiator
$15.00 Gas Tanks
$15.00 Gas Tanks
$15.00 Gas Tanks
$20.00 1985 Ignition Box
$25.00 1983 Magneto
$10.00 Voltage Regulator
$10.00 CYL heads
$10.00 CYL heads
$15.00 Chain Case
$15.00 Chain Case
$15.00 Oil Tank
$10.00 Collant overflow tank
$20.00 1983 Wiring harnass
$20.00 1987 Wiring harnass
$25.00 2 Cylanders (Need replating)
$40.00 2 suspensions for parts
$5.00 Ignition switch
$25.00 1 like new ski (V-max or Exciter)
$15.00 Jack Shaft
$15.00 Exhaust canister
$25.00 Drive wheel assembly
$40.00 1985 Head Light assembly (Complete)
$15.00 1983 Headlight housing
$15.00 Oil Pump
$5.00 Recoil Handle
$3.00 Hood Support Cable
$5.00 Brake Cable
$10.00 Right Strut cover
$15.00 2 Fuel pump with petcocks
$10.00 Tail Light
$10.00 Tail Light
$3.00 Recoil handle stop
$5.00 Upper radiator hoses
$2.00 Hood Strap
$5.00 Oil pump cable
$7.00 Steering shaft colars
$5.00 Handle bar mounts
$5.00 Front Fuel pump
$10.00 Front Strut Mounts
$15.00 Front & Rear Motor Mounts
$5.00 Right Upper Body Mount
$10.00 New Clutch side engine seal
$10.00 Water Pump and impeller
$5.00 Right carb insulator
$5.00 Coolant temp hose
$10.00 Shock tower caps
$15.00 New bag of exhaust inserts
$5.00 Fuel pickup
$10.00 Left & Right Shock supports
$15.00 Water pump outlet
$5.00 Throttle Cable
$5.00 Rear side markers
$5.00 Temp Gage pieces
$5.00 Hood Plate
$12.00 Coolant bypass with hose
$5.00 Choke cable
$15.00 Water pump drive with impeller
$5.00 jack shaft collar
$10.00 brake assembly
$10.00 Speedo drive assembly
$10.00 Left & Right hood supports
$10.00 Head Bolts
$15.00 Left & Right strut supports
$5.00 Gas stank straps
$5.00 Gas lid latch
$5.00 Fuel pump mounting bolts
$5.00 Gas tank strap mount
$5.00 Gas tank mounting bolts
$5.00 Misc Idler wheels (each)
$8.00 Petcock
$5.00 Coolant bypass
$5.00 Motormount bolts
$5.00 Left Carb insulator
$5.00 Exhaust springs
$5.00 Brake cable
$5.00 Oil tank heat shield
$5.00 Radiator mount
$7.00 6 foot of new spark plug wire
$15.00 secondary clutch
$20.00 4 panels (in rough shape)
$15.00 Steering shaft
$15.00 Gear Case housing with seal
$10.00 Steering pod upper cover
$5.00 Gas tank lid cover
$15.00 Ignition coil assembly
$5.00 Ignition coil without caps
$5.00 Front strut Cover
$5.00 Right steering insulator
$5.00 Left Side Airbox sheild
$5.00 Holddown exhaust springs
$10.00 Front left strut cover
$5.00 Leftside panel pins
$5.00 Rear fuel pump with bracket
$5.00 Windsheild mounting bolts
$3.00 Tail Light mounting bolts
$5.00 Recoil rope guide
$3.00 secondary cluth bolt
$5.00 Suspension mounting bolts
$5.00 Thermostat
$2.00 Hood light nuts
$10.00 Speedo and Tach assembly
$3.00 Steering cover pod screws
$5.00 2 hood straps
$3.00 Coolant hose holddown bracket
$10.00 2 Oil Injection Fuel Line T's
