my second 81 srx almost finished
here are some pictures of my 81 srx that is almost finished. it has a freshly rebuild motor in it with all new gaskets, new cylinders, pistons,  piston rings, brand new oil pump and new carbs and all new fuel line. i also polished the ports in the cylinders  and also polished the manifolds. so here are some of the pics that i took.
i will put more up when its all finished.
Re: my second 81 srx almost finished
Should be interesting to se the numbers on the Cyls and Head. Same as the Motor number on the Oil Pump Cover?
the cyls are 8u9 same as the head and oil pumpSRX500F82 wrote:Should be interesting to se the numbers on the Cyls and Head. Same as the Motor number on the Oil Pump Cover?
You have a Cover From a SRX 500 Motor does your Cassie Number Match Up?Keith3046 wrote:the cyls are 8u9 same as the head and oil pumpSRX500F82 wrote:Should be interesting to se the numbers on the Cyls and Head. Same as the Motor number on the Oil Pump Cover?
no but it does have the srx 500 crank in it with the vmax 540 cyls and 540 head oil pump on the motorSRX500F82 wrote:You have a Cover From a SRX 500 Motor does your Cassie Number Match Up?Keith3046 wrote:the cyls are 8u9 same as the head and oil pumpSRX500F82 wrote:Should be interesting to se the numbers on the Cyls and Head. Same as the Motor number on the Oil Pump Cover?
WOW i wouldnt be using that bottom end that is worth some $$$$$$$$$$$$$$$$$, how did you polish up the motor so nice?? and clean up so nice...
thank you i can tell you its alot of work. and all done by hand i used steel wool and steel wool pad and the polish that i used is called Autosol Metal Polish works great its alot of work polishing up the motor.chrisrider63 wrote:WOW i wouldnt be using that bottom end that is worth some $$$$$$$$$$$$$$$$$, how did you polish up the motor so nice?? and clean up so nice...
Ya its nice but that bottom end has got to be worth some money i dont know if i would be using it unless you have a few...
yes i have a few motors but they need rebuildingchrisrider63 wrote:Ya its nice but that bottom end has got to be worth some money i dont know if i would be using it unless you have a few...
The Prefix Number RT499 on the Cover. Or if you name it as Pump Drive - Gear indicate the 499cc 8R9 SRX 500 Motor.Keith3046 wrote:no but it does have the srx 500 crank in it with the vmax 540 cyls and 540 head oil pump on the motorSRX500F82 wrote:You have a Cover From a SRX 500 Motor does your Cassie Number Match Up?Keith3046 wrote:the cyls are 8u9 same as the head and oil pumpSRX500F82 wrote:Should be interesting to se the numbers on the Cyls and Head. Same as the Motor number on the Oil Pump Cover?
as Chrisrider63 told you be careful with the SRX Crank. Very Very hard to find spare parts for it if you blow it up
yes i know. i got this motor when i bought my other srx off a guy that had this motor in it and he blow it up.SRX500F82 wrote:The Prefix Number RT499 on the Cover. Or if you name it as Pump Drive - Gear indicate the 499cc 8R9 SRX 500 Motor.Keith3046 wrote:no but it does have the srx 500 crank in it with the vmax 540 cyls and 540 head oil pump on the motorSRX500F82 wrote:You have a Cover From a SRX 500 Motor does your Cassie Number Match Up?Keith3046 wrote:the cyls are 8u9 same as the head and oil pumpSRX500F82 wrote:Should be interesting to se the numbers on the Cyls and Head. Same as the Motor number on the Oil Pump Cover?
as Chrisrider63 told you be careful with the SRX Crank. Very Very hard to find spare parts for it if you blow it up![]()
and did some 81 srx come with the 500 motor in it?
No that RT499 bottom end is a rare collectors item and i would not be using it as only there are 15 srx 500's out there and only a few people from this site have one.
yes i know. i know that they are rare. and i know you dont want me using it but its all i got right now. i have put over 2500 into my srx and a 1000 into the motor.chrisrider63 wrote:No that RT499 bottom end is a rare collectors item and i would not be using it as only there are 15 srx 500's out there and only a few people from this site have one.
its to much money spent i cant just leave the sled with out the motor.
how much would the bottum end of srx 500 be worth ???
It is worth what someone is willing to pay.  I am sure there was a time that it was worth $2000+   Given that those machines have gone for $10,000+ with an original engine.
Someone with more knowledge with the SRX 500 may know what todays prices would / could bring. I know that i wouldnt run it in anything unless it was in a SRX 500 chassis. Lower ends and cases for the 440 and 540 are easy to find. It would probably be best to preserve that bad boy.
