1985 Vmax?
1985 Vmax?
What other primary clutch will work on my sled is the SRV the same.
Brad
Brad
mmm other than what?
i suggest the 102-C or 108... i would defintly be looking for a 102c its by far the easiest set up in my opinion
ooooooh... yeah i dont know hahaha.... im sure somebody does though..... the clutches say 102-c on the faceplate and im gonna guess the taper is the same but dont qoute me.... someone jump in here and help hehehe
clutch
If you can find a clutch that looks like this it will work
its off a phazer and srv and others it is not the right one but will work you just have to mess around abit with springs and weights . Polaris p 85 will work as well but again the clutch needs to be set up properly to get the performance desired!!! A stock phaser or srv will run your sled decently at least enough to get out for a ride anyways!!!
The Phazer & SRV YPZ clutches have a lip on the back side of the fixed sleeve that fits into the seal of the gear drive for the oil pump assembly in which the Vmax 540 does not.
Vmax-4 Clutch
I use a Vmax-4 clutch, it has a offset hub that moves it away from the sheet metal. A Polaris Belt and make sure you back cut the helix 0.90 to allow for the wider belt and more shift. I set the secondary offset at 10 - 11 mm.
Those Yamaha/ Comet clutches IMO are the achillies heel of these sleds. They work well when new but are very hard on rollers.
/Dan
/Dan
Well I picked up a 87 Vmax in great shape with a bad piston i'm going to part out my 85 if you guy's need anything shoot me a email. I will post pictures of the 85 when we get back from the vintage ride.
Brad
dlevene77@yahoo.com
Brad
dlevene77@yahoo.com
