				1985 Vmax?
				Posted: Mon Feb 16, 2009 5:00 pm
				by 2quick4u
				What other primary clutch will work on my sled is the SRV the same.
Brad
				Posted: Mon Feb 16, 2009 5:34 pm
				mmm other than what?
  i suggest the 102-C or 108... i would defintly be looking for a 102c its by far the easiest set up in my opinion
				Posted: Tue Feb 17, 2009 9:23 am
				by 2quick4u
				I was wondering what other machines did yamaha use the vmax clutch on SRV, Phazer, etc. My buddy owns a junk yard full of Yamaha's and I was hoping to get a clutch for my Vmax.
				Posted: Tue Feb 17, 2009 2:07 pm
				ooooooh... yeah i dont know hahaha.... im sure somebody does though..... the clutches say 102-c on the faceplate and im gonna guess the taper is the same but dont qoute me.... someone jump in here and help hehehe
				Posted: Tue Feb 17, 2009 4:46 pm
				by 2quick4u
				Thats ok..........I need a clutch I want to use the sled on the vintage ride this Friday.
				clutch
				Posted: Tue Feb 17, 2009 8:05 pm
				by jefflanthier
				If you can find a clutch that looks like this it will work
its off a phazer and srv and others it is not the right one but will work  you just have to mess around abit with springs and weights . Polaris p 85 will work as well but again the clutch needs to be set up properly to get the performance desired!!! A stock phaser or srv will run your sled decently at least enough to get out for a ride anyways!!!
				Posted: Tue Feb 17, 2009 8:55 pm
				The Phazer & SRV YPZ clutches have a lip on the back side of the fixed sleeve that fits into the seal of the gear drive for the oil pump assembly in which the Vmax 540 does not.
				Vmax-4 Clutch
				Posted: Wed Feb 18, 2009 5:43 pm
				by Vmax535
				I use a Vmax-4 clutch, it has a offset hub that moves it away from the sheet metal.  A Polaris Belt and make sure you back cut the helix 0.90 to allow for the wider belt and more shift.  I set the secondary offset at 10 - 11 mm.
Those Yamaha/ Comet clutches IMO are the achillies heel of these sleds.  They work well when new but are very hard on rollers.
/Dan
				Posted: Thu Feb 19, 2009 12:35 am
				by 2quick4u
				Well I picked up a 87 Vmax in great shape with a bad piston i'm going to part out my 85 if you guy's need anything shoot me a email. I will post pictures of the 85 when we get back from the vintage ride.
Brad
dlevene77@yahoo.com
				Posted: Thu Feb 19, 2009 1:15 pm
				by 2quick4u
