Vmax coil
Vmax coil
I was wondering if anyone would have a charge coil for an 84-87 vmax,it is the one for the handle bar warmers. The part # is 8X6-85521-10-00,it is the top one on the side that has two coils on top of one in other in the stator. If so please PM me with a price . Thanks
							JEFFERY M  FOURNIER
What happened to the original one?
My lighting coil went out a couple months ago. I took the stator out and found the wire had broken off the coil. I unwound the coil and found that it had 40 feet of #18 wire and the middle third had burned the insulation off the copper. The wire had dents in it and it looked like a failure waiting to happen. I wrapped the core with Scotch 27 electrical tape and rewound new wire on the old core. Once the new wire was in place, I wrapped it with another layer of Scotch 27 electrical tape.
The tape is woven glass with a thermosetting adhesive. It gets hard as epoxy once it gets warm.
I tested the lights last night and they worked fine.
It took about a half hour to wind the coil.
Current sleds:
1986 Yamaha VMAX 540
1992 Yamaha Venture 480
1993 Yamaha Viking 540
1997 Polaris RMK 700
Here is the first item I found on a search. The price is more than we normally pay because it is much more rugged than we use. It will get you started on a search though.
http://mouser.com/Search/Refine.aspx?N= ... re&FS=True
http://www.belden.com/pdfs/MasterCatalo ... e/3.25.pdf
http://www.alliedelec.com/Search/Produc ... b=Overview
Lower right corner of the following catalog page:
http://www.alliedelec.com/Catalog/pf.aspx?FN=469.pdf
Note that heavier wire is available than listed on the catalog page.
Current sleds:
youll probably want to save the head ache and check out this site.....
http://www.psep.biz/store/yamaha_snowmo ... _parts.htm
