83 V-max oil injection question
My sleds: 2014 Yamaha Viper-1999 Yamaha V-max 500-1996 Yamaha Ovation-1992 Yamaha V-max 4-1973 Yamaha SM292, and room for more!
						Welcome to V.V. !  I have always lined the dot to the opposite cable end.   Someone correct me if I am wrong but, if the gap is wider/longer that should be less oil ?   Don';t forget if this is not the updated red dot oil pump then maybe someone tried to give it less oil with the stock black dot pump ?
This is from the Service tuning data in the Articles
AutoLube- Pump Color / Control Rod Adjustment Red/ Adjustment Mark @ Full Throttle
Pump Plunger Stoke Min/ Max 0.50~0.55mm/ 2.15~2.27mm
Output @ 200 strokes Full Throttle/ Idle 5.40~5.71 cc/ 1.26~1.38cc
