Temp Gauge wanted to buy
VectorBoy
Post by VectorBoy »
Help! Looking for a temp gauge for a 83 V-max. NOS or used in working condtion. Let me know what you have. thanks alot.
My sleds: 2014 Yamaha Viper-1999 Yamaha V-max 500-1996 Yamaha Ovation-1992 Yamaha V-max 4-1973 Yamaha SM292, and room for more!
F.Y.I. You have to remember the odd thing about the stock temp guage is that it does Not register much if at all under normal operating temps but, will go up when you have an issue. =Poor O.E.M. setup. See the garage forum Tyler is working on a solution !
VectorBoy
temp gauge
Post by VectorBoy »
Thanks for the input and It does make sense. It seemed like when I ran it hard the gauge went up a little bit but the next time I looked it was back down. I hope I dont have a issue and see the gauge come up. Thanks again
hi
Post by chrisrider63 »
I have some older style exhaust temp gauges for sale, if anyone wants to make an offer.
The 83 gauges were as Tyler said they didn't register much if at all. They were the same gauge as they used on the SRX's and they ran about 140 degrees or so,but when the came out with the 540 in the Vmax it only runs about 103 degrees or so ,so you can see why they didn't register much.They really were good gauges,they just didn't match the running temps of the new engine. In 84 yamaha came out with a new gauge to match the running temps of the 540 engine and they worked great ,I have one in my 83 and it runs about half way in the green ( there are no numbers on them just color codes). I would recommend anyone with a 83 to update to the newer gauge ( Yamaha should have updated them )IMO. Maybe this will help you out as the newer gauge should be easier to find.
hi
My temp gauge isnt working, it sat in a garage for ten years before i got it so what do i check to get it working again, i have the 86 sooooo im assuming its the update...
tfin
testing temp gauge
Post by tfin »
Remove the sensor from the hose fitting, and warm it with a heat gun or pass the flame of a lighter under it. If the needle moves, it is working. You can also put it into boiling water at 212.
sxr1000
Post by sxr1000 »
If it sat for ten years make sure the lines in and out are not pluged,I have had this happen on both my vmax"s and the temp gauge would not work.
