http://www.racenssr.com/calc.htm
MPH Calculator
Fill in the appropriate information below, Then click  when finished.
Engine RPM
   Chain Case Gear ratio
   Clutch ratio (1.00 w/o Overdrive)
   Driver diameter in inches (7.07, 7.75.)  The speed in MPH is  miles per hour.
The same DRIVER size and RPM will give the following speeds based on the following gear ratio changes.
1.40 1.45 1.50 1.55 1.60 1.65 1.70 1.75
RPM / gear ratio x wheel circumfrance / 1056 = MPH
gear ratio  =  bottom gear / by top gear       example  18/33 is 1.83  gear ratio
wheel circumfrance  =  height of driver    7 inch driver  is 7 times 3.14 = 1.666 is circumfrance
8250 / 1.83 x 21.98 / 1056 = 93.93mph
at 8250rpm with 18/33 gearing and 7 inch drivers=93.83 mph
							Gear Ratio interesting
