81 SRX Jetting
81 SRX Jetting
Nedd a ruff idea were to start with the jetting on my 81 SRX. Does not have the stock carbs on it, has 38mm Mikunis ( power jets from 84 V-max ) and was wondering were to start with main and pilot jets. Everything else is stock as far as I know. Thanks.
My sleds: 2014 Yamaha Viper-1999 Yamaha V-max 500-1996 Yamaha Ovation-1992 Yamaha V-max 4-1973 Yamaha SM292, and room for more!
Re: 81 SRX Jetting
340 mains. 150 powerjet 40 pilots. and if your useig oil injection, backup with pre-mix at 50:1 3:16 (YAMMIE TONY)
Re: 81 SRX Jetting
I'd say the same as Tony ! Possibly, a little richer pilots for starting out ?
Stock Vmax540
Carburetor- Mfr.- Type/ Size/ Qty/ ID Number Mikuni- VM38/ 38mm/ 2/ L:80N-00 R:80N-00
Main Jet/ Main Air Jet 290/ 2.5
Slow Jet/ Slow Air Jet/ Air Screw 1- 1/2
Pilot Jet/ Pilot Screw 40/-
Needle Jet/ Jet Needle- Clip Position/ Cut Away/ Air Jet Q-0/ 6DH1-4/ 3.0/
Power Jet/ Power Air Jet L:135 R:130/ L:1.5 R:1.4
Fuel Inlet Valve/ Float Level 1.5/ 18.1mm
Idle Speed 1500 rpm
Stock Vmax540
Idle Speed 1500 rpm
Re: 81 SRX Jetting
I finally got around to installing the 340 mains and took it out for a spin today. The thing seemed to run very fat but it was also 33 degrees outside. Going to test it again when it cools down again. Does this sound correct to you guys? Will the warm temp effect it that much? I want it set up for colder temps. Let me know what you guys think. Thanks
Re: 81 SRX Jetting
Big difference between 34 and a normal riding temp like let's say 24 degrees, so I'd say wait and test when the temp goes down.
