85 vmax flooding and or not firing on mag side
I rebuilt the engine new crank seals and it doesnt fire below 3000 rpm on the mag side once it comes up it does..lol. I dont get it. Im thinking fuel pump its the only thing/s I didnt rebuild. Or that pilot jet in that side or slides are that far out.
Re: 85 vmax flooding and or not firing on mag side
We all often over look the simple, hate to ask... you did replace the plug or switch sides ?
-Is there gas in that pipe flooding the cylinder
-Choke on the mag side sticking
-Needle & seat sticking
-Float hanging/bad/misadjusted
-PTO side fuel pump leaking into crank case
Im wondering if its a fuel pump leaking down into the crank I have problems with that side Ill take it off. The clutch isnt engaging though either....If I take the belt off the sled revs up, if the belt is on it wont rev above 4000rpm.
