ignition help 87 vmax 540
i'm having problems with my ignition system.  The sled will start and run for awhile then die. When i pull the plugs and check there is no spark. if i wait for awhile it will start agian after some time.  I got a clymer service manaul for 84-89 but my sled is not in it.  I need schematics and specs for resistance testing badly! any help is much apreciated!   - Josh
							New sleds are for skirts!
1987 vmax 540 liquid cooled 42" widening kit
Hello !    This and all specifications can be found in the Articles !
Lighting Coil Color Code/ Resistance/ Output Yellow~ Black/ 0.25 Ohms� 10%/ NA
Handlebar Heater Coil Color Code/ Resistance Yellow-Black~ Blk/ 0.77 Ohm� 10%
Ignition Coil Resistance Primary/ Secondary 0.12 Ohm � 10%/ 4.0 Kohm � 20%
Source Coil Color Code/ Resistance Brn~Red/ 25 Ohm �10% White- Red~ Red/ 10 Ohm � 10%
Pulsar Coil Color Code/ Resistance White- Green~ Black/ 100 Ohm �10%
Spark Plug Type/ Gap/ Torque NGK BR 9EV/ 0.7~0.8mm/ 2.75 m/Kg (19.9 ft/lbs)
Ignition Timing 1.6mm BTDC
