Took my rear suspension out of my '83 today and it is a mess. Every bearing is bad and the rear crossbar was all chewed up because the bearing stopped turning and it ground literally 2/3 of the way through. It's shot. I have an '81 parts sled I'm going to look tomorrow to see if that cross shaft will fit. I just bought this sled last year and put maybe 50 miles on it with the plan of going through it this fall. Alot of damage considering it only has 1397 actual miles. Cosmetically it's a gem but I need to check everything out after seeing this.
Does anyone know if these cross shafts are still available from Yamaha or if my '81 SRX shaft doesn't work, I would have to look for a used one or have one machined.
Any suggestions??
Robb
Rear Suspension '83 V-Max
Try the yamaha factory website at:
http://www.yamaha-motor.com/sport/parts/home.aspx
press parts catalog, snowmobiles, 1981, srx440
to view the SRX parts.
press parts catalog, snowmobiles, 1983, vmx540
to view the vmax parts.
If the part number is the same, they are interchangable.
If the part number is not the same, you need to do more checking.
