1983 V-Max
stv1991
1983 V-Max
Post by stv1991 »
This is my '83 V-Max 540. It's a work in motion. Not done yet but getting better every few months.
Robb
wow that looks like a really good place to start!!! as a matter of fact if you told me you just finished it i would believe you... what to you plan on doing? widening?
stv1991
Post by stv1991 »
My plan is to completely go through this sled. I have already gone through the rear skid. I replaced all 13 bearings and ordered/replaced any worn out parts with new Yamaha parts. They were not cheap. Then I have gone through the front end. Took out all the TSS bushings and greased them up and replaced all new tie rod ends and shim kit. I also replaced the primary clutch. My bellypan has dents but I have a used pan that is perfectly straight. I also have an extra set of narrow skiis. I'm going to powdercoat the skiis and bellypan and then replace. I will also take out the motor and replace the crank seals and check the remaining bearings and lastly ceramic coat the exhaust. I plan on bringing it right up to or very close to show winning condition. It's a nice piece to start with as it only has 1300 miles on it.
Robb
Robb, nice to see some of the old ones being taken care of !
That is another sweet 83 what is the chassis # on that one?
