81 srx help????
badcats
81 srx help????
Post by badcats »
how do you get the gear off the end of the crankshaft on a 81 srx to change the seal
messina1974
Re: 81 srx help????
Post by messina1974 »
I used heat to expand the gear and it came right off the crank. hope this helps
Re: 81 srx help????
Take the bottom end to someone that has a press. Even if you get it off with heat you would not want to use heat with the new seal.
Re: 81 srx help????
Post by chrisrider63 »
Heat with a blow torch with the old seal but be sure to mark the spot of the seal where it goes on with the new seal i put the gear on the fireplace for half hour and it slide right on.
