85' Vmax Pump Drive Gear O-Ring Specs??
KylejSmith
Post by KylejSmith »
Looking for the Specs of the Pump Drive Gear O-Ring. I've been to a few O-Ring shops and they can't seem to match it, anyone have a # I could give them to speed this up?
Thanks,
Re: 85' Vmax Pump Drive Gear O-Ring Specs??
Which o-ring ?
20150814114337164.pdf
(63.8 KiB) Downloaded 869 times
KylejSmith
The large one that goes around the whole housing.
KylejSmith
Its the one, that the "NOTE" points to, telling you to grease the O-Ring.
Yamaha Part # is 93211-44445-00 I have reused them as long as they are in good condition you should be OK. If you can find the right diameter seal in a roll you could always fit it in the groove with the ends at the top and put a drop of silicone on the ends. It is always best to find the original one if you can, these are just a few alternatives for you if you can't..
