What is the diference between those instrument panels? I have seen in the parts manual and wonder what have been changed? I thought they all was like.
81 and 82 has 8m6-77711
83 and 84 has 8u9-77711
85 has 80n-77111
Intrument panel vmax 540 and 81 srx 440e
arctic srx 500
Yamaha- the way it should be
not sure if they are mechanically different but i know the 81 goes to 10000 on the tach i assume the 82 does to... and the guage faces look different... but i imagine they are interchangable
arctic srx 500
oh the tank cover! hmmmm never really compared those... im thinking after 84 they ditched the tether... and at least in 86 there was the fuel shutoffs on the tank cover... also 86 on would have snaps for the seat cover i imagine... i dont see why you couldnt swap them around if you wanted
arctic srx 500
Yes you have right. The 80n tank cover has not the hole for the tether. Now i see the difference between those.
The difference between the 81/82 and the 83/84 are the hole in the front of the tank cover, where the rubberflap shall be(over the airbox), and the 85 did not have the hole for the tether.
Thanks Tyler 440.
Thanks Tyler 440.
i try... not always right but im usually pretty close
The 85's on up used the T.O.R.S. (carb shut offs) instead of the tether cord !
arctic srx 500
